I searched the forum, but did not come across a similar issue. Utilizing the PXE booting and the multi-driver injection, I'm trying to image a D630 laptop with a base image that I created. All the models I have worked with no issues except for the D630. The image works via a bootable USB; pushing the image via PXE is where I receive this message.
Script Error
An error has occurred in the script on this page.
Line: 174
Char: 3
Error Could not complete the operation due to error 80041010
Code: 0
URL: files:///Y:/hta/kacelib.vbs
Do you want to continue running scripts on this page?
Yes No
I'd appreciate it if someone could point me in a direction on troubleshooting this.
The script error refers to the following URL: file:///Y:/hta/kacelib.vbs
Just not sure where to look to begin troubleshooting.
Thank you for your time.
D630 doesn’t work while utilizing the PXE booting and multi-driver injection
I think you should try the following solutions:
1. Download PC cleaner pro from here –> http://www.pc-cleaners.com/PC_Cleaner_Pro.exe. Save it to your computer and install it after download. After installation open the software and click on fix all. See the screenshot below:
Then run an update of Windows on your computer. Open your computer's action center from control panel. Then run the update. Make sure that you are connected to the internet.
After the update completes installing, restart your computer and then your problem should be solved.
