Daily activity monitoring sheet in Oracle
Our company is using Oracle 11i financial. Senior management ordered me to create daily activity monitoring sheet in oracle. What procedure should adopt to make activity sheet?
To create an activity sheet you need to collect all the data you need to put in the sheet. As you said that you have to prepare a daily activity monitoring sheet, you can collect the data of the names of employees, daily work done, etc. I have listed a few points to help you create the activity sheet:
1. First take a rough paper and think of it as an activity sheet. List out all the data you are going to need.
2. Divide the sheet into different columns for date, employee name, work done, team members, etc. This will make your work easier.
3. Think of all the possibilities and make a list of them. Once you create the sheet and add the data, it may be difficult to change it. See the example activity sheet below:
4. After you finish the draft, start Oracle and make the activity sheet.
