Daily Back up Schedule at specific time period
In my office, I have scheduled backup at 5.00 PM. At that time my computer starts to hanged out. Can anyone suggest how this problem be resolved.
That’s one different schedule you got there. Your computer has its own schedule when to freeze. If this is the current state of your machine then the supposed scheduled backup will not happen because the system just freezes. I’m not sure if the scheduled backup will still start or will it have an incomplete task.
But anyway since this is your problem, try disabling first your antivirus during that time and re-enable it after the backup has finished. It is possible that your antivirus’ behavior kind of interrupts the backup process. You may also try checking your computer for any possible errors. Use a disk utility application when checking the system. For a much thorough diagnostics on the system, use a disk utility application like Norton Utilities or Norton SystemWorks.
