Damaged BTtray.exe Application Error In Devices
What is BTtray.exe? What is the use of the application? Why does BTtray.exe application error occur? How to fix this issue?
BTtray.exe is a Bluetooth Tray Application. It is a system tray icon that allows the user to see the status of the Bluetooth connections. It allows the user to access the configuration and settings for the device. The BTtray.exe error occurs due to some issues in the Bluetooth software; the process fails to start and stops to work. To fix the issues, just reinstall Bluetooth software, scan for malware or try cleaning Registry.
This error is an example of “side-by-side configuration” error. According to Microsoft, you may receive “side-by-side configuration” error if your computer is missing the correct Microsoft Visual C++ runtime components for the type of system you are using (32-bit or 64-bit). To fix the problem, download and install one of the following Microsoft Visual C++ update according to your platform architecture:
If your operating system lacks the required Service Pack update, download the required Service Pack update from the following:
For Windows 8, you should update to Windows 8.1 from the Windows Store. The “BTTray.exe” file is an executable file developed by Broadcom Corporation and part of the HP Bluetooth program.
Notifications
