Damaged Hard Drive Data Recovery
I have damaged hard disk. The data that is lost is very relevant for me? How can I perform the data recovery?
Firstly, you should know whether the failure in your hard drive is a physical drive failure i.e. an external damage or a logical drive failure i.e. the data stored is lost.
 If there is an external damage, it may be one of the following-Â
In above cases of external damage, it is better to hand over the drive to a hard disk recovery specialist as you have only one shot at the data recovery.
If there is data damage, then you can recover it by yourself by using any of the data recovery software.
You need to perform the following steps-
