I am facing a technical problem with my Samsung tv. I purchased it about a year ago and it worked fine so far. Recently half of the screen just loses color. I know it is not conventional but a tap around the back helps to fixes the constant flashing. Given it is one year old, I cannot bet on guarantee. Can anybody help me please?
Damaged samsung screen tv to be fixed
Hello Samuel!
Before jumping in to conclusion on repairing an LCD Television (TV) please be mindful that once you tampered any part of this the product is not eligible for warranty. Or even unscrewing the panels or the back part of your TV. There are simple hacks circulating Google or YouTube that you can just cut the jumper and flickering will disappear. We don’t have any guarantee that it will work with all flickering issues with any type and model of Samsung TV. I suggest you bring it first to experts to get a positive results rather risking your TV and it might cause you more money.
