Fulton
Posted on - 08/05/2011
All I want to ask. I wanted to ask. I assemble a PC. AMD Phenom X4 processor II 955, Biostar 880 GB +, DA 460
If AMD really noisy?
Then I install the game Resident Evil 5, but my PC suddenly smells a little burnt and is very noisy and its temperature increases, then I remembered the word friend was told to activate smart fan configuration.
I try and noisy sound missing.
I was afraid to enable smart fan does not think about danger?
Is this dangerous to turn on the Smart Fan?
I think you have burnt some parts of your motherboard and even if they are safe than after some use it will be burn all motherboard and system will shut down.
But the smart fan might help here because it is made for providing cooling to processor and if it overheats then can cause serious damage to your motherboard. So use smart fan ASAP and go to bios and turn on system fan it will take some loading in system.
When I got burnt my laptop processor once then I came to know about smart fan and now I am using my laptop without even turning off for several days.
Fulton
Nice I don't worry if I turn on Smarfan now.
It is extremely helpful for me Ethanparker3055
