Data Analysis On Excel 2010
Can we use different engineering and statistical functions in MS Excel? How can I perform Data analysis on Excel 2010?
Answered By 0 points N/A #91921
MS Excel provides a Data Analysis Toolpack, which allows you to perform engineering and mathematical tests on the data. It allows you with the following features- ï‚§
  • ANOVA-Single Factor
  • Descriptive Statistics
  • Correlation
  • Covariance
  • Histogram
  • Fourier analysis
  • Z-test
  • t-test and many more.
You have to enable it to enjoy its tools and functions because it is disable by default.
To enable it, do the following-
  • Click File->Options.
  • Select Add-Ins->Analysis ToolPak.
  • Click Go.
In the Add-Ins dialog box, Select Analysis ToolPak->OK.
After you have enabled it, you can access it by clicking Data->Data Analysis.
