Data Grouping in Excel Sheet.
Hi user _Sumon,
I made you a solution that may solve your problem. First you should do is to input those data or group in the excel. After doing so highlight those cells you want to group. Press Data on Menu Bar > Groups. Upon clicking it, will be prompt of rows or columns. On our case we want it by rows. Then you will see a Minimize button. If you click that all those names will be hidden.
Just Click Maximize button to see those names again.
Hope this helps you with your problem,
There are many ways to insert a data group inside a worksheet. You mentioned you have 25 columns in your excel sheet. Try this official link to get solution. Here you’ll have to complete the data group before inserting it as a data group.
Notifications
