Data Line Formatting in PowerPoint
My problem regards charts with data lines formatted as dashed while using PowerPoint 2007 on my Sony Vaio – Windows 7.
When I edit the lines it shows the correct form, but after I finish it appears as a solid line.
After I reduced the line size to 1 it worked perfectly but it is too thin and if I increase the size in 1.25 it shows as solid.
Could you please give me an idea on how to fix this?
