I want to buy a solution to administrate and storage virtual machine,
I want to know which is the best storage solution (Attempt time navigator, Symantec)
It must support Linux, storage data from MySQL, Apache.
I'm searching the solution which is the most advanced, Offers archival solution heterogeneous environments.
lee hung
75 points
Data protection and storage security
Hi Barbara,
I will recommend that you use the Hyper-V management tools for your storage which offers a virtual connection by accessing a virtual machine remotely. You need to know the specifications of your system and get the version of Hyper-V tool that will work best with it.
You can download Hyper-V tool from the internet. (Note: Hyper-V tool works best with Windows Server 2008, and I am not so sure if it can work on Linux, but you can give it a try).
Otherwise you can try the Universal Virtual Machine Manager which is designed for Linux and it offers a high performance services in administration. Other virtual machines for Linux include plain_old, version and convert just to mention a few.
Hope this helps.
Lee Hung.
