mjido012
200 points
Posted on - 04/22/2011
Hello everyone, in fact I have big problem, plus it's quite urgent! : s I am currently creating a form step-by-step allows a user to assist in finding the proper computer by using it will basically: > Step 1: I request the use he intends to make (edits, office, video games) > Step2: If he prefers a mobile or fixed > Step 3: The maximum budget for this client (from a choice that I offer different levels) The responses are therefore check the Inbox dan. So off I set my form with my presentation page, second page step 1, third step in step 2 and step 3 fourth page. So I have a html / css with the form, then a php file for data recovery Inbox chosen by the customer in the form. The trouble is that I can not retrieve the data selected by the customer voila all: / Thanks in advance.
azerty03
How to Create Forms using HTML/CSS
What's in your $ _POST or $ _GET in PHP file following submission of your form?
mjido012
200 points
it contains the variable nombreEcran "I put in place in relation to the screen that you are, if you want a piece of code to better understand the thing does not hesitate because I'm galley monster: /
As a beginner of php ^ ^
Thank you for the help:)
azerty03
Yes send the code, otherwise it will be hard, HTML
azerty03
I'm surprised with your code I get three answers each time, you can specify the problem, because then I'm lost ^^
