Database Engine of the SQL server has encountered a problem
80 points
Posted on - 10/22/2012
Hi guys,
My SQL server has encountered a problem. I connected the proper illustration of Database Engine of the SQL server. However, I switched the database to the server and received the error message.
It failed to backup. Have you any idea for the issue?
Please help.
Thanks a lot.
Error backing up database: BTData. Check to make sure the path is
correct.
Exception of type ‘System.Exception’ was thrown.
