Database error shows when launching G Data Antivirus 2012
Hello Experts,
I am attempting to try out the 30 day free trial version of G Data Antivirus 2012 Beta and I find that an error occurs while launching the antivirus. G Data Tuner reports an error when opening database. I have attached a screenshot of the error received. I tried running a program update from ‘Actions’ after choosing Software updates. But this did not fix the problem. I also tried running a virus signature update manually and found that I had no luck with this step either. I did not face any issue while downloading this software and the installation too completed smoothly. Should I try reinstalling the software to fix this issue? Did anyone else face a similar issue? Please help me by sharing any ideas on how to go about fixing this issue. I am using windows 7, 64 bit version on my computer. Any help will be greatly appreciated.
Image:
Error:
G Data Tuner
Error opening database (C:ProgramDataGDATAAVKTunerAVKTuner.mdb).
