Database Gets Error With the Code Whenever Run on the Server
Hi.
I need help with this problem I am encountering. My database gets an error with the code, Set appWord = GetObject(, “Word.Application”) whenever I run it on the server.
However, it works perfectly fine when I run it on my hard disc. Could you help me resolve this issue? I can’t make any update because of this error.
Thank you in advance for your help.
‘ActiveX Component Can’t Create Object’
Answered By 25 points N/A #91013
Dear Hannah timothy
According to the error message u received "ActiveX component can't create object", multiple reasons for this behavior maybe happened. The DAO (Data Access Objects) may be not registered properly, one or more references may be missing, a utility database reference may be invalid, you may be don't have the permissions required for the required libraries or finally, a wizard file is damaged. In order to resolve this issue, please refer to the resolutions of  each cause in this page by Microsoft support https://support.microsoft.com/en-us/help/319844/you-receive-a-activex-component-can-t-create-object-error-message-when. This article explains the common causes of the error message and the methods you may use to resolve them.
Hope this may help you.
Best of luck
