Database to Hyper Text Mark Up Language (HTML)
anyone knows here about HTML and mysql, I have question, is it possible that file location is stored in database and you will retrieve it HTML?
This is simple and easy thing. When we need to store the images and some other kind of things like that we can store those in database also.
But when we are going to retrieve those in to html it will take long time to load the data.
So it is not good idea to store images in database.
Instead of that what we are doing is we put all the images in to one folder and we store the path of the particular images.
The path is just a set of text. So we can retrieve those as much as fast.
And then using that part html can load the image.
So it is very easy and possible thing to do.
