Ciana
Posted on - 11/02/2011
Good day to all.
Please tell me how can I solve this problem?
I had a hard drive failure, when I open the re-installed Lotus Notes I received a "database local access protection” message.
what shall I do?
Thank you.
Database local access protection message problem
Try scanning the hard drive for any possible errors.
If you have a disk utility application installed on your computer, run it to check your hard drive for possible errors in the file structures.
If you are using Windows operating system, you can use its disk check tool.
Right click on drive C and then select Properties.
Click Tools tab.
Click Check Now.
Check Automatically fix file system errors and then click Start.
If Lotus Notes was already reinstalled and it is still giving off errors, it is possible that Windows has an internal error that is preventing the application from running normally.
If the error is already intolerable, try formatting your hard drive and install Windows again.
