Good day!
I am trying to launch Holdem manager, and on with connecting to PostgreSQL when I encounter this message: “A connection to PostgreSQL could not be made.
Would you like Holdem to Manager to attempt to start the service?”
So, of course, I clicked “Yes” but it doesn’t start.
Any ideas on why this is occurring?
Thanks!
DB Control Panel
A connection to PostgreSQL could not be made. Would you like to have Holdem manager attempt to start the service?
DB Control Panel A connection to PostgreSQL could not be made
Hi Mike C Coriell Thanks for posting your problem there.
This error occurs due to firewall or window updating problem. This is usually a firewall or a windows update issue.
First of all you should try to reboot. If you get no help to reboot then try this.
Start > Programs > PostgreSQL > 8. x > Stop Service Start > Programs > PostgreSQL > 8. x > Start Service
If the second option also do not helpful then delete the following file postgresql8.xdatapostmaster.pid file And reboot And the last way is to reinstall the PostgreSQL
Whitaker Sorg
