Dcom Server Process Launcher Windows 7
I am facing a very serious issue since yesterday. My laptop simply starts to reboot every twenty or so minutes. Just before restarting, it shows the error message dcom server process launcher Windows 7 services terminated unexpectedly. How to fix this?
Answered By 0 points N/A #324470
The dcom server process launcher service is a very important service that is essential to keep your system working correctly. As it is obvious in this case, there is some problem with this service on your computer.
The first thing you need to do is run a full scan of your computer for viruses and malware. You can also run an online scan if you want. Secondly, try to restore your computer to a previously working state from the control panel. Lastly, check if the service is active on your computer. To do this, go to Administrative Tools in the Control Panel and find services. Then go to dcom server process services and right-click to enter properties. Under the General tab, make sure the service is set to automatic. If nothing works, contact tech support.
