mart cullen
10 points
Posted on - 05/12/2012
I have installed DDPid file v1.0 on my computer. When I try to open a file using it, I get these error messages:
ERROR: Track 12 error (image file c:mcd1IMAGE.DAT, Offset 693202608 bytes, track size 79688112 bytes):
;Track size and image offset do not match with actual file length (772537920 bytes).
;Log file closed at 2009 02 03 02:11
Please help. Thanks in advance!
DDPid file v1.0 Error Messages
If this is the first time you encounter this problem, try restarting the computer then try again. If it still fails on the next attempt, try uninstalling the program then check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like PC Tools Performance Toolkit, or Norton SystemWorks. Any errors in the hard drive’s file system may cause problems to some applications and files.
The typical errors that can be found are cross-linked files, lost file clusters, incorrect reported free space, too much allocated file space, and more. Some of these errors don’t affect a file or application but some of them do. Install the program again then try it if it works.
