DDR 2 2GB 800 GHz
I have a desktop at home. An Intel Pentium Dual Core with an ASROCK as a motherboard and a DDR 2 1GB RAM. The thing is I want to change that RAM for a DDR 2 GB 800 GHz. Will it damage my desktop?
Hi
No man this will not damage your desktop but before purchasing this make it sure is it compatible with your motherboard or not if yes then it will work very good and make your desktop like an airplane but if it is not compatible then done make a mistake of purchasing RAM DDR2. So first check it out is it compatible or not if yes then surely you should purchase it otherwise don’t purchase it. This is the easiest solution you have and this make your problem solve and you will get rid of the problem after reading this solution so hope this will help you very much and make it very good for you.Â
