Dead Island has stopped working
Hi everyone,
I have played DeadIsland using my friend computer lot of time and now I want to play it using my computer,
Error: DeadIsland has stopped working
Hi everyone,
Maybe your dead island installation files are corrupted. This is the most common reason why many application do not work on the other hand windows batch file can be also corrupted that cause the game to stop working. If you are using an illegal version of the game, then there maybe a problem with the installation of using it. Uninstall it an use a legit version. You also have to ensure that your computer meet the minimum requirement to play the game. To know that you can browse via Google. Then you have to ensure that your system is compatible with the game , I mean your OS has to compatible with the game version. You can try re-installing your OS than install the game again
To solve or solution to your problem in your Dead island games is just simply open the dead island file, and then attempt to find the code:deadislandgame.exe, after that you just right-click the properties and then you just simply disable the desktop composition to fix black screen, then maybe there is a file deleted or corrupted from the folder, attempt to uninstall it again, and then try download the Dead island again from a trusted site, after your download, just simply reinstall it again to your PC, and then after install the Dead island simply restart your machine.
ben
Hi there user:
Locate the Dead Island Folder in your program, and you will find game.ini. You may now locate ‘EN’ because you need to change that letters into lower case ‘en’. Now save it and then close. I’m pretty sure this will work so you can again play it.
Thanks for visiting us here at techyv.com. Feel free to post again.
Before installing “Dead Island”, check that your computer meets the requirements. Dead Island supports Windows XP, Windows Vista, and Windows 7. It requires 2.66 GHz Intel Core 2 Duo or faster processor, 1 GB RAM, video card with 512 MB video RAM and supports Pixel Shader 3.0 and Vertex Shader 3.0, and 7 GB free space.
If you verify that the game is compatible but you can’t start the game, try disabling UAC. Click “Start”, “Control Panel”, “User Accounts” then click “Change User Account Control settings”. In “User Account Control Settings” dialog, move the slider all the way down to “Never notify” then click “OK”. This now disables UAC on your computer. If this doesn’t work, try starting the game as administrator.
Right-click “Dead Island” and select “Run as administrator”. If this worked, set the game to always run as admin. Right-click “Dead Island” and select “Properties”. In “Properties” dialog, go to “Compatibility” tab then under “Privilege Level” section at the bottom, check “Run this program as an administrator” then click “OK”. If the problem continues, uninstall and reinstall. Download the free version of Revo Uninstaller and install it.
Once installed, start Revo Uninstaller then select “Dead Island” among the applications and click “Uninstall”. Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, close Revo Uninstaller then install “Dead Island” back.
Before reinstalling, disable your antivirus or internet security temporarily.
