Dead pixel on my sony walkman z1000
Just found that I have dead pixel on my Sony Walkman z1000.
It completely ruins the looks.
What is Sony's policy for replacement regarding dead pixel?
The dead pixel is nothing but a ruined pixel in the screen. in order to fix it you need to replace the entire screen of the pallet with a new one. The pixel that is ruined cannot be replaced as a single. If you are within warranty period, then you need to just contact the nearest customer care center and the n you need not pay to the services. Incase if not, then you have to pay a lot too much. A better option is to buy new one ads the price would reach the new webcam today. Try searching the market for it.
1. The problem is an access configuration problem. See the security of the folders that you have copied. These should have full access to your account and the IIS manager and the networking. The remote host has the read and execute permissions. All the problem is the read only property of the folder which you have copied or the entire path from the root to the destination file that is the web- config. Check the security. If no problems with it then you need to see the problems with the web- config file which must have been set to write-protected. Open it and then set there.
Incase if not, then you have to pay a lot too much. A better option is to buy new one ad the price would reach the new webcam today.
