Dealing with a Firefox problem
Good day,
I was on a message board this morning and received the following message:
I must have conflicting files or something somewhere on my comp but don´t know where to start any help?
Error:
DashboardClient quit unexpectedly.This report will be sent Apple automatically.
Answered By 0 points N/A #139112
Hello friend,
This error " Dashboard client quit unexpectedly ", is a common error which cause when updating software's. The iMac has give a solution for this problem. This is causing because of corruption in the iMac system files or its trusted programs. The error shows that it will sent message to apple, which wont help this situation.
You need to download the combo update and install it. The experts says that its worth of a try, but in most cases it works. So download the application and install it into your system, which will make your system to the old condition.
I searched for this application and here is the link. ( https://support.apple.com/kb/DL1399?locale=en_US ), try it. Good luck
Hope you get your answer, If you got any other problems ask at Techyv, have a nice day.
