Dealing With Error Code 0x800723b
I tried to activate my windows in my new laptop but when I tried to do so an error occurred that says error code 0x800723b. I tried hard to resolve it can somebody give a solution that will surely work?
I hope these steps will work for you,
Get your Windows
Close all programs that have just opened this surface unit.
Once all programs are closed, you must place the indicator in the lower-left corner of your screen and right-click on it. This action may result in a popup menu appearing on the screen.
Examine the various options in the pop-up menu until you find to Execute and select it. If you choose to Execute, an Execute command box appears on the screen.
If the Run command box appears on your screen, type “slui 3” (without quotation marks).
If you made a typing error with this command, click OK. This action may cause Windows to activate on your screen. You will be prompted to enter a legitimate product key.
If you entered a legitimate product key for Windows 8, click Enable.
Notifications
