Decide which anti-virus is best
Hello Experts!
Which do you think is the best anti-virus between Avast and ESET SS 5?
I would love to hear your personal feedback and user experience.
Thank you very much!
Hello Experts!
Dear Stanley
If you can afford to pay a few bucks then I would suggest ESET SS 5.
The features are really good and secured one relatively than the Avast.
Good luck.
Rajkumar
Hi Mr. Steward,
Dear Mr. Stanley Steward,
What's your question tells is that you are having confusion about using one of them as a best in functionality.
The popularity of avast in common people and offices is much more than the ESET SS 5 antivirus.
Avast provides more security than the ESET SS. When you attach your any device to your PC, it warns you about the viruses which the device may have. The big one virus is a Trojan horse virus which if once is connected to your PC,will hide all your folders and make its own folders.
So avast will warn you about it, but not ESET SS. Although ESET is too good for your PC security level, but not for protecting it from Trojan horse like viruses. It determines the threads if by mistake you device transfers viruses, via scanning.
Make ESET your second choice as compared to avast.
Hi there, the truths being both software is good enough to protect against basic protection your computer needs.
I would recommend Avast however, due to its Malware protection while ESET does not protect against.
Here are the pros and cons of both Antivirus Software.
Avast! | ESET |
Has Anti-Rootkit |  Does not have Anti RootKit |
Has Anti-Spam | Â Has Anti-Spam |
Has Anti-Spyware/Adware | Â Has Anti-Spyware/Adware |
Has Anti-Virus |  Has Anti- Virus |
Has Automatic Updates | Â Has Automatic Updates |
Has Boot-Time Scan |  Has Boot -Time Scan |
Has Email Protection | Â Has Email Protection |
Has Firewall | Â Has Firewall |
Has Keyloggers |  Does not have Keyloggers |
Has Malware | Â Does not have Malware |
Does not have Parental Controls | Â Has Parental Control |
Has Real-Time Protection |  Has Real – Time Protection |
Does not have Trojan protection | Â Has Trojan Protection |
Does not have Web Protection | Â Has Web Protection |
All the best in choosing the one that suits your needs.
Thank you all experts for your answers, namely Rajkumar, Stanislava yap, Amna butt, Michelle B, ans ssuvo64.
All your answers are very helpful.
I also like how you compared the best anti-virus against each other.
Narrowing it down, it seems like the best is Eset and Avast. Thank you all again.
Thanks TechyV!
Means a lot!
Hi Stanley StewardÂ
Check out this Techyv post too because this post is also addressed your problem. Go that page and get more information.
Seeking a good and the best Anti-Virus
