“Decoding dvd error while writing through Cheetah”
Hey I guys my cheetah dvd burner give error message decoding dvd error while trying to write dvd, what I should do?
The cheetah dvd burner giving you the error message regarding the decoding dvd error indicates that you need to decode the movie with some other software you want to burn through this drive. For decoding the movie you may take help from the concerned decoding software. You can also download the software from their respective website. It will help you to decode your collected or downloaded movies and make them compatible with the cheetah dvd burner to burn. The system is a simple task. This way you can get rid from the error message. I think it will help you.
I hope you understand it.
