Decoding DVD movies and writing into Video CDs
I have a bunch of DVDs where I have the complete reference for a visual project I am working on. I need these videos to be separately written into VCDs. Do you know any utilities for decoding DVD movies and burning into disks?
Thanks in advance for your response!
Answered By 0 points N/A #199188
Hello Fidelgiancarlo,
Yes you can decode any DVD movie by using a software which can be downloaded from media converter soft website. You can work with the DVD's  even without having a DVD rom. Once the DVD is decoded you can easily burn into separate disks. You can also use free DVD decoder burner software for decoding and burning purpose. This will solve your problem.
