Dedicate server DoS Window ??
Hello Greetings,
I have a dedicated server with HostGator, and run a fairly large website on it. The issue that I'm having is that little kids with a DoS programs have the ability to take down my website from one IP with 300+ connections. For some reason the firewall doesn't pick it up, and I have to enter the IP in the "/etc/firewall/IPDROP_GLOBAL" file, and reboot the firewall. After that, it takes about 3-4 minutes for the site to come back up.
Is this something that would normally happen on any host? Is there anything I can do to prevent such little attacks?
This how I find out how many connections are on my server:
netstat -anp |grep 'tcp|udp' | awk '{print $5}' | cut -d: -f1 | sort | uniq -c | sort -n
Server specs:
Intel Xeon 3110 (Dual Core) 4 GB DDR2 Memory 2 X 250 GB Hard Drive 1,500 GB Bandwidth 13 Dedicated IPs
Thanks,
