The Deep Fish Finder features
Hi Ney,
Deeper FishFinder that is designed for Android and iOS is also known as the First Sonar Fishfinder for Smartphones. It is designed for amateur or professional fisherman to know the location of the fish, depth, water temperature, bottom contour of water and many more. It also works with the conjunction of smartphones and tablets.
The ball deeper is like a small tennis ball sized water proof sonar ball that has a 6.5 cm diameter and it floats on water. It also supports devices with iOS 4.0+ or Android 2.2+. When the deeper paired with a smartphone, it allows people to see the view of the pond bed. It uses a Bluetooth connection to display the information about the fish, the pond bed, water temperature and obstacles within 150 feet on the screen of a phone or a tablet. It can be used in ocean, river or lake.
The deeper has three holes in it where you could tie a fishing line which could be used for different types of situations. It scans the waters up to a radius of 50 meters deep after dropping the ball into the water. It could work in the temperature from -10 to +40 degrees. It includes rechargeable battery that lasts for six hours and could be charged via micro USB.Â
For more information you could visit the website: https://deepersonar.com/us/
Dear,
A fish finder is a powerful instrument that is used to locate fish underwater. The most common features of the deep fish finder are:
Thank you.
Deeper Smart Sonar is a wireless, castable echo-sounder compatible with Android and iOS devices. With its Wi-Fi connection enabled, it allows you to maximize both the distance of the device holder and the Deeper Smart Sonar up to 330 feet or 100 meters and the depth range up to 260 feet or 80 meters.
With its advanced high frequency technology, it allows the Deeper Smart Sonar to instantly transfer more accurate data. The higher scanning frequency allows the device to capture faster moving objects while the scanning resolution measures the smallest types of objects to deliver the highest quality echo-sounder data available in a single, compact wireless device. You can cast Deeper Smart Sonar to any spot in the water.
While floating in the surface of the water, it connects to your Smartphone or tablet and transmits information used for locating fish location, exploring bottom structure, learning the temperature, getting depth information, and contour and vegetation. It operates based on echolocation and Wi-Fi technology. To download the app, go to Deeper – Smart Sonar.
To buy the unit, go to Deeper Smart Sonar or Deeper Start Smart Castable Fish Finder.
