Hello, is deepburner compatible with Windows Vista? I’m only seeing that it is compatible with the following OS: Windows 95, NT, 98, 2000 and XP. I’m using Windows Vista and decided to quite Nero as it’s always hanging up on my computer. I’m trying out other burner software and see if it perfectly operates on my PC.
Is deepburner compatible with Windows Vista?
Hi Raymond Adem,
Yes deepburner is compatible with Windows Vista. It means you are trying to avoid Nero. It will provide facilities for you as like as Nero. It is also fast and easy to use. By using this you will burn both CD and DVD.
What's new in this version:
· Already added optimization processes for burning data CDs/DVDs.
· Language files updated.
· All known omissions are Fixed.
If you need to download then here a link for you-
http://download.cnet.com/DeepBurner-Free/3000-2646_4-10250994.html
How to download this file? Here included a picture for you
Best of luck
Hello Raymond Adem,
The answer to your question is yes.
Deepburner is compatible with Windows Vista.
Go to following link and download it for you or use this alternate site.
Hope this helps you.
Thanks,
The older version of Deepburner really does not run in windows vista because of the platform switch from Windows XP with 32 bit it goes to Windows Vista 64 bit but now with the new version like Deepburner Pro and Portable, it can run in different Platform even in 86 bit of windows 7 and if you want to download it just follow this link http://www.deepburner.com/?r=download
Hope it helps.
