Default Mp4 Video Player For Windows 10
Which are the best MP4 video player for Windows 10? What are the features of these video players? Does it play MKV and HEVC format files? Which is the default player available in Windows 10?
Windows 10 has a default video player, which is Windows Media Player. It supports all the commonly used extensions like MP4, MKV, and HEVC. But it does not play AVI format which is a drawback to the player. The best alternatives to this player are GOM player, 5K player, and KM player. These players support almost all the formats like MP4, AVI, ASF, FLV, WEBM, M4V, MPEG1/2, RMVB, RM, MKV, AVC, HEVC, etc. It takes up less CPU power when playing videos like 1080p, 4K which few players struggle to do.
If you’re looking for a media player that’s best for Microsoft Windows 10, then it would be no other than VLC media player. If it’s not the best media player for Windows 10, it is one of the most widely used media player on the internet. It supports a wide range of audio and video formats that you can play on your computer.
The Matroska video format or the MKV video container is supported. The latest VLC media player supports Windows XP Service Pack 3, Windows Vista, Windows 7, Windows 8.x, and Windows 10. Among the codec it supports includes MPEG-2, MPEG-4, H.264, MKV, WebM, WMV, MP3, and more. It doesn’t only run on Microsoft Windows but also on OS X, Linux, iOS, Android, Unix, and several more operating systems.
Another media player that’s best for playing video is PotPlayer. It supports Windows XP, Windows Vista, Windows 7, and Windows 8.x. This is the ideal media player for slow machines that will allow you to play HD movies without slowing down your system’s performance.
