Default Number of Tabs in Excel
                                            Hi!
Default number of tabs in Excel depends on its version and may vary in different versions as in Office 2007 where the default number of tabs is only one. The number of tabs don't create any issue while working.
It is, therefore, less important to consider the number of tabs while launching the software. However, if you are facing any problem, please do mention it and I will try my best to resolve it.
Hope it helps.
                                            Hello Josh.
Whenever you launch Microsoft Excel the number default worksheets or tabs are 3 (three). Sheet 1, Sheet 2 and Sheet 3. You can change the name to any name. You can also add more worksheets at any time with any name you would like. It's for the user convenience so that any one can rename it, add or remove any.
Thanks
