My Scrapbook factory Version 5.0 isn't allowing me to open the default page setup. I do not understand why I can't do that. Can this problem be solved and if yes how do you go about it?
Thank you
Default Page Orientation in Scrapbook Factory 5.0
It's quite unfortunate to saying about. Here I discuss something about tour problem.
Unfortunately, there's no way to change the default page that opens in the background of the software. when you first launch the software, however if you have the splash screen set to open on start-up, you can always then click on the blank template that fits the formatting that you desire.
Also there is an alternative way to get resolved. At first Select your desired blank page, and then save it prior to doing any work on it. Now save it on the desktop, or make a short-cut of it on the desktop (or wherever else you would like), and can double click on that project to open it. It would then open that blank project in the software program.
For more you can visit the site,
Hope this all may help. Thanks.
