Defining Sstray Exe
As I observed my system’s performance slow as compared to other days, I decided to go a check through all the processes going on in my system. When I opened the task manager I observed a task named sstray exe in execution. However, being unaware of this file and clueless about when I downloaded it. I landed into confusion that whether this file is important for my system to make it work?
Answered By 0 points N/A #321375
Defining Sstray Exe
sstray.exe is not part of the Windows operating system and has relatively few problems. The sstray.exe file is in the C: \ Windows \ System32 folder. The proverbial file sizes for Windows 10/8/7 / XP range from 77 to 824 bytes (22% of all occurrences), to 2,054,736 bytes, and to four numerous variants. https://www.file.net/prozess/sstray.exe.html
This file is not a Windows system file. The program does not have a visible window. The file is digitally signed. Sstray.exe is able to record keyboard and mouse input and control applications.
