Defining The Installer Error Code 0xc8000222
What is installer error 0xc8000222? I have come across this and, I wanted to know about it. Since I work in this IT field. If you could brief me with this error?
The error 0xc8000222 is a Window Installer error. It arises when you’re trying you update or the readiness tool itself. The Readiness also depend upon Windows update. The Microsoft has developed this Windows System update readiness tool which helps you to provide with this solution to the errors that’s preventing from the up-gradation of the Windows System. It helps you by checking your Operating System to verify that your Windows update process is working properly.
You can fix this by Running Administrator at the command prompt. You will see the Windows command processor; you need to run with escalated access. Then select “yes” you can Run an SFC to know about the errors in the system. To know Run “SFC\Scan now”. Make sure you use or update the latest version. The version should indicate the date.
