I used to view a design website named 99designs.com. I used to view it without any error. But, i do not know for what reason the website can not be viewed from my laptop. But the website is active and can be viewed from other computers. I can view all websites without only 99designs.com. What is the reason and solution?
Rezbelle
A definite website cannot be viewed from my laptop
Hi. Since you were able to access the website from a different computer then this means the website is working. Does your laptop have a security software or firewall installed? Check or try to add the website on the allowed websites. Your firewall settings might be blocking the website. What browser are you using? To isolate a browser issue, you can try accessing the website from a different browse. If it will work then it’s a browser issue. If not then it could some settings blocking your connection to the website. You can also try to reset your browser to its default settings. Here's how to restore IE settings. Launch IE- tools-internet options-advanced tab – restore default settings.
