Davis Avon
20 points
Posted on - 08/12/2017
Hello, everyone, I was eager to know about the working system of Microsoft .NET Framework 5.0 (Windows Management frame work). Kindly provide the fundamental features of the framework. To those who helped me thanks in advance.
Definition Of Microsoft.NET Framework 5.0 (Windows Management Framework) And Features
The .NET Framework from Microsoft is comprehensive. It is consistent programming model which is for building apps. It gives the visually best user experiences, seamless and secure connection.
It provides:
- Just Enough Administration (JEA).
- It creates custom types with the help of Powershell classes.
- Improvement in PowerShell Script is debugging.
- Information Stream.
- Software Inventory logging (SIL).
- Network Switch management with PowerShell.
I don’t think you can refer Windows Management Framework 5.0 as Microsoft .NET Framework 5.0 because I think they are different. According to the release history of Microsoft .NET Framework, the latest release at the moment is .NET Framework 4.7 and it was released on April 5, 2017. It supports Microsoft Windows 10.
.NET Framework is a software framework developed by Microsoft that works mainly on the Microsoft Windows operating system. It has a huge class library called FCL or Framework Class Library as well as give language interoperability across several programming languages which allows every programming language to use codes written in other programming languages.
Applications that were created for .NET Framework run in a software environment called CLR or Common Language Runtime. The CLR is a program virtual machine that offers services like memory management, security as well as exception handling. Common Language Runtime (CLR) and Framework Class Library (FCL) together make up .NET Framework.
The WMF or the Microsoft Windows Management Framework is a driver that updates several management functionalities in Windows 7 and Windows Server 2008 R2 which can be installed on Windows XP, Windows Vista, Windows Server 2003, and Windows Server 2008. If you wish to install it, download Windows Management Framework 5.0.
