Del Laptop with best specifications
Asked By 7060 points N/A Posted on -
Helo,
I am going to purchase Laptop for the first time.
I am a college student and want to make practices of computer language lessons.
I have totally no idea about Laptop specifications.
My money range is 30,000 PKR.
My personal observation is, may be Del Model can be with in my money range.
But I know nothing what specification should be.
Please some one guide me
Best Answer by Gutierrez knowles
Answered By 0 points N/A #84723
Hi Anonymous,
The following Products are available from Dell:
  • Vostro – Essential
  • Latitude – Professional
  • Inspiron – Value
  • XPS – Performance
  • Ultrabooks™ for Business
However, you have your range up to 36,000 PKR for a Dell Laptop with:
Vostro 2520 laptop:
  • Intel® Celeron® Dual Core B820 processor (1.70GHz)
  • Windows 7 Home Premium, 64bit, English
  • London Slate Gray
  • 2GB Single Channel DDR3 SDRAM at 1600MHz
  • 320GB 5400 RPM SATA Hard Drive
  • 8X CD / DVD Burner (Dual Layer DVD+/-R Drive)
  • Intel®HD Graphics/HD Graphics 3000
  • 1 Year Basic Hardware Service with 1 Year NBD On site Service after Remote Diagnosis
  • 5.2 lbs
  • 15.6” laptop with touchpad
For around 30,000 PKR, you can choose any of the following from Asus or HP, which should be ok for programming lessons:
Asus Eee PC 1005HA
  • Processor: Intel Atom N280
  • Processor Frequency: 1.66GHz
  • Memory: 1GB DDR2 RAM – 533MHz
  • Hard Drive : 160GB – 5400RPM
  • Chipset: Mobile Intel 945GM Express
  • Graphics: Integrated Mobile Intel GMA 950
  • Operating System : Windows XP
  • Display : 10.1 inch
  • System Weight: 2.9 Pounds (1.3KG)
HP Mini 110 -3606TU / 110 – 3607TU
  • Intel® Atom N570 Dual Core
  • Hard disk capacity – 320GB
  • 2GB DDR3 RAM
  • 10.1" LED Backlit Widescreen
  • Free DOS
  • Intel® Graphics Media Accelerator 3150
  • Dimension of 191 * 268 * 32 mm.
  • Weight of 1.31 kg.
  • 0.3 mega pixel web camera and Bluetooth.
  • Warranty 1 year.
  • 6 cell standard batteries.
HP Mini 110 -3608TU / 110 -3609TU
  • Hard disk capacity – 250GB
  • 1GB DDR3
  • Genuine® Windows® 7 Starter Edition
  • 6 cell standard battery.
  • It has a webcam with an integrated digital microphone, Bluetooth and WLAN.
Gutierrez knowles
Answered By 0 points N/A #84724
Hello
When buying a laptop with the projection you've got, there are some several factors to consider to get the best from the much or little you have.
Take for example the following:
1. Processor
to be on the safest side the best is the one with the highest speed, but putting in the back of you mind the inevitable subject of battery life.
2.Memory
The size of your memory determines how work load our machine can hold to.
For a programming having a bigger RAM is to you best advantage.
With the price you have got and specification for dell model you can go for this several types
Dell latitude series d630,e6400,e4300
But for more types you can visit usanotebook.com.
Hope you can check them out if anymore question just put them up.
