Bert Suarez
Posted on - 11/11/2011
My laptop has a fault. Its operations have since been hampered. Whenever it has been operating for one or two days, the sound system works when playing a video but the video itself begins running a sideshow, and eventually, the sound goes out completely. The laptop also takes a lengthy period trying to open pages in the web. I therefore urgently need to change its settings so anybody please help.
Delaying video sound and delaying pages to open
Hi Bert,
You are having many problems with your laptop right now. These are my solutions to your problem, kindly follow this steps:
1. Copy your valuable files to your USB as a back-up.
2. Reformat your hard drive.
3. Install Operating System (WINDOWS).
4. Install Drivers (Motherboard, Sound card etc.).
5. After you install the Operating System and Drivers.
6. Insert your copied valuable files back-up to USB.
After you have done this process i can guarantee you that it will now completely fix. With regards to your Video Slide show problems kindly upgrade your video card.
Thanks,
Deanmark Kingstone
There can be more than one reason for the issues you experienced with your laptop. One or more of the below may be the reasons for your issue.
1. Your laptop might have viruses that will utilize your bandwidth or your laptop RAM. Do a fully virus scan to check this.
2. You might be experiencing a bottle neck situation with your internet connection. Check your band with.
3. You may also try to upgrade your RAM. This will speed up your laptop.
4. Also check your drivers if they have sufficient free bytes.
The ultimate solution if all the above failed to go for a formatting of your hard disk.
If you let your laptop run for days, you just need to give it a rest. Just shut it down and unplug it from the power if it is connected to the charger for like one to two hours (1 – 2 hours) to let the hardware cool down. If humans need rest, so are the machines.
Now, if you have a problem with the web browser opening pages very long, the most likely cause is the amount of browsing data it accumulated since it is running for days and you don’t clean up browsing data. To try cleaning your computer, download the free version of CCleaner and install it. Once installed, start CCleaner and clean your system.
This should empty the browsing history of all your web browsers not just one. Another way is with PC Tools Performance Toolkit. Just download and install it. Once installed, start PC Tools then click the “1-Click Optimization” button on the “Dashboard” tab to optimize your computer.
