Sync Contact List on Outlook
210 points
Posted on - 06/24/2011
Hello mates,
My contact list has been triplicated automatically. So when I go to contact list, each name is 3 times there. All 3 lists are named as desktop. I can't delete any of them. If I select 1 if them from menu, it works only for once; later all 3 lists are shown again.
First time, I sync my Nokia with MS Outlook and then sync BB with MS outlook to transfer all contacts to my new BB. The list duplicated while I returned from abroad (I was on roaming) and switched on my BB when I came back.
The list triplicated when I took out the SIM once. But next time when I changed the SIM once again, the list did not duplicate again. The SIM contact list is empty. The 1st list shows wireless sync 'Yes'. The next 2 list shows Wireless Sync 'not available'. I sync with MS outlook regularly to update.
🙁 Any ideas?
