Hi guys,
What is the fastest way to delete billions bulk email list? My email address was full of bulk emails and I want to get rid of this and delete them all. But there are almost billions bulk email list. What should I do? Please give some good advice and suggestion.
Expecting some help, thank you.
Delete Bulk Email List and Unsubscribe Email Address
Hi Brenda Lopez I searched solution that may help you solve your problem.
If you are using Yahoo mail, then here is a process of deleting those emails.
1. Log in your yahoomail account.
2. Click Options> Mail Options
3. On the Behavior Tab under show messages, check the “in a scrolling list (show preview pane)
4. Click Save.
5. Prompted with a message just click OK. It will refresh the Page
6. Go to your inbox; scroll down until you reach the last email.
7. Upon reaching the last email, Check the FROM box. It will check all the emails you have.
8. Click Delete and confirm delete.
Hope this information helps.
Process will depend on your email account options. If you are using Gmail follow below steps.
1.      Login to your Gmail account
2.      Click on the check box above the mail list.
3.      It will select all the mails in that page and then you can click on delete button.
4.      Likewise you’ll have to go through every page and delete them.
5.      Unfortunately there is no option to delete all the emails in a one click.
