shaheen
20 points
Posted on - 07/11/2011
I have 92 MB text file and here is many rows that repeats and i want to remove repeating rows for this purpose i download this software from internet "Remove (Delete) Duplicate Lines & Words In Multiple Text Files S.exe" but this is not registered you tell me from where i can download its registered version or tell me other solution which you think this is best. If you provide me any software then that software should be registered.
Regards.
Delete Duplicate Lines from text file.
Sobolsoft. This offers a solution for people who want to remove duplicate text line from one or more text files.
This was really helped to me. you can download this from here.
You can use Duplicate cleaner software. It is user friendly and a Freeware. This software find duplicate files and delete the file to recycle bin. It has a large search parameters and you can also move duplicate file to another location.
It has Intelligent Selection Assistant and Fast Scanning and accurate duplicate comparison.
I am giving you the Download link it is completely Free
