Delete history files in Split View Manager
I split out some confidential documents in split view file manager. I want to delete history and files from manager. How can I delete this data?
I see that you want to delete the history and files from the split view manager. Deleting files from the split view manager is an important task. Some softwares store the information and are not deleted simply by clicking the delete button. So try to clear the cache and the stored items. Do not open confidential data in softwares that you do not trust. You can try the following steps:
1. Every software has program files that are stored in your computer in the C drive.
2. Go to the C drive and locate the program files of your software in the program files folder.
3. Open the cache folder and select all the files and press delete.
4. Go to the stored items folder and select all the items and delete.
Hope this information helps you.
