Delete my account from TechyV
In many website the account setting is always available for all modifications which have been you needed you can setup all security setting, add account image, and etc.
To delete the account, Go to the Setting where are the options for delete the account, add security and all other setting of editing. In account setting tab you can subscribe or de-subscribe the email alerts. Account setting tab gives more tools all we are needed. I hope the above information helps you in the deleting of account.
Hi, shahid,
If you don't mind. I willing to say you that your required account may be Porn sites or some Adult review sites or others. You do not show it, because there have different sections in various sites.
But every account which you open look at very carefully on FAQ. However, if your account remaining like forum sites or others you first search in Account, Account settings or Profile edit profile. After sign in your page.
Settings and Edit option mostly contains the Deactivate account option. I just give you hints. Therefore you have to search in this way my friend. And make sure your account will be inactive.
