anonymous
7060 points
Posted on - 08/09/2011
I am Google Chrome user. I am browsing it for few months. Now, I would like to erase all the history from my Google Chrome in my computer. I do not know how to delete history from this software. Now, I need the process of deleting history.
Delete my Google Chrome history
Hi!
Here is a simple instruction on how to delete your Google history and increase your performance in browsing:
First, click the start button and then point to all programs.
Click Google Chrome. Once it appears, click the wrench– it's an icon in the right top corner in your monitor screen. You can see the image.
Select the browsing data clear from your menu, there the clear browsing data opens.
Just tick the browsing history and select all the browsing history you want to erase. Options include the last few weeks and last day.
Lastly, just click the clear browsing data.
hillsong
Chrome stores history in a cache. Cache stores images, scripts, addresses and other parts of websites while you are surfing, temporarily. To remove this history, you need to:
Click the spanner shaped icon on the browser toolbar.
Select Tools from the dropdown list.
Select Clear browsing data.
Select the checkboxes for all types of history that you want to remove in the dialog box that appears.
You can select the amount of data that you want to delete in this box.
Select beginning of time to delete all history.
Click Clear browsing data.
