bombom
Posted on - 10/04/2011
One time, I did a paper on the laptop ex-boyfriend. the problem is if I save a document by using the former name, can make a mad girlfriend right now,especially if the boyfriend is the last time to see the documents and any document with the name of your ex.
Other cases, you unlock some secret documents (eg on a laptop Good evening friends or cafe), after you're done, of course, secret documents that you open will be listed in the document or history, it means that everyone can have the appearance of a document or tracking that you have.
how to Delete Recent Documents in Office 2007 for example in Word, Excel or PowerPoint?
DELETING DOCUMENTS FROM WORD (OFFICE) 2007’S RECENT DOCUMENTS
Click on Microsoft Office icon at the left upper corner of your window.
It will show several options but select the ‘Word Options’ towards the bottom of the dialog box.
It will open a dialog box and on the left side, select ‘Advanced’ from the list provided.
Scroll down this new dialog box up to the ‘display’ section.
Underneath this section, look out for; “Show this number of Recent Documents”.
Set the value to ‘0’ and then click “OK”.
kipsang
How to delete recent documents in office 2007 word
1. Open a word document.
2. Click on the Microsoft office icon on the left upper corner of the window.
3. Click on Word Options on the lower right corner of the resulting window.
4. Click Advanced option then scroll down to Display section.
5. On ‘show this number of Recent documents:’ option change the value to zero (0).
6. Click OK.
7. Close and open word again and it will have deleted the recent documents.
Hope it will help.
