Romy Shane
10 points
Posted on - 07/08/2011
I was cleaning the table of my computer when I accidentally pressed shift + delete keys. And I just have deleted one of the hidden files. I was worried then, my computer is doing well now and still running smoothly.
My worry is that, errors may show up after many days just because of what happened. Any idea about getting back what I have deleted?
Deleted hidden files from the computer
Good day,
Here is a solution which can help you with your current trouble.
You can use Shadow Explorer in recovering a file that is deleted already. Just download it then install it. After installing it, launch the shadow explorer as an administrator by right clicking the icon and select run as administrator. Now, select a shadow copy of the hard drive that you know when the file is deleted you could simply select a version that been present before that file been deleted.
Go to the file location which has deleted accidentally, right click the file or the folder that you wish to recover and select export. Select then a location where you want to save the file you want to have back again.
Tekken6
Format the partition is best way to delete the hidden files.
