Shubash
300 points
Posted on - 04/29/2011
Hello Everyone,
I am an iPhone user. Unfortunately I've deleted my, Safari iCone from my iPhone. It's my browser software. I can't browse from my iPhone now. What should I do? Please give a solution.
Shubash
sumya
Deleted iCon from my IPhone 3G 16GB?
You have deleted Safari icon from your iPhone. Most of the iPhone and iPod users got this problem. Don't worry you can get your browser software easily. Just follow my instruction.
First – Connect your iPhone to you Computer and wait, let your iPhone be detected with iTunes.
Second – Be sure your internet connection is OK. Because for restoring your settings, you need internet connection.
Third – Once it detects with your iTunes, then hold both together; the home button and on the top of your iPhone you can find on/off switch.
Fourth – Wait for a while. Let your iPhone to be restarted. When the Apple logo Appears in your screen, just take off your finger from on/off switch but don't take off your finger from Home, just hold it. After some time, you'll see an iTunes Logo and the cable picture in your phone screen. It's means your iPhone now is in recovery mode.
Fifth – Now click Restore. Your iPhone started restoring. After finishing restoring, there is your Safari browser software.
Your iPhone is ready to use.
Cheers,
Sumya
Shubash
300 points
Hey,
Thanks it works. Now I am able to use my browser, in my iPhone. Your instruction was really helpful in restoring my iPhone. It has been also updated.
Cheers,
Shubash
sumya
Assume, so now you can use your iPhone smoothly. Just one important note. When you update your iPhone, do select the backup option because if you don't select it, then you'll lost your all data.
Cheers,
Sumya
Shubash
300 points
Yes, you are right. All my previous settings and all data has been deleted. I just forgot to mention. Have to be careful in future.
Thanks,
Shubash
sumya
As I mentioned that whenever you update your iPhone do check that, you select backup from restore. If you follow this, you'll never lost your previous data. Thanks.
Symya
bappy
Dear Shubash,
I have just read your message, you have deleted your Safari icon. It's very simple to get back your safari icon in your iPhone. What you have to do is, connect your iPhone to your computer and wait for iTunes detect your iPhone. Once it detects, just restore it. After completing restore, you'll find your safari icon. Thanks all you have to do.
Cheers,
Bappy
