lillion
10 points
Posted on - 09/30/2011
Hi All,
Deleted mailbox in exchange 2010 recovery?
I deleted a designer user account and mailbox from AD & Exchange. Now how can I retrieve it?
Can anyone help me retrieve the mailbox and user account please.
When you delete a mailbox it is filed in the disconnected mails and you need to find the disconnected mails in Exchange before you could restore it. In the Mailbox Store, right click the Mailboxes object and click Cleanup Agent.
Right click on the disconnected mailbox and choose Reconnect then select the correct user from the dialog box that will appear. Click Ok. If you want to reconnect the mailbox to a new object or user, you can also do that.
You can create a new user object but clear the check box in Create and Exchange Mailbox. Then follow the steps in reconnecting disconnected mailboxes. You will have to choose the new user after choosing reconnect.
